This article helps identify and troubleshoot common issues in PTV Route Optimiser.
It covers typical situations such as:
Orders are not imported
Tours cannot be planned
Tours are not exported
Tours are not transmitted to telematics devices
Reporting is not working
If you experience an issue in PTV Route Optimiser, first perform the general checks and then follow the troubleshooting steps for the relevant problem.
General checks
Before starting technical troubleshooting, try to narrow down the issue.
Please clarify the following:
What exactly is not working in PTV Route Optimiser?
When did the problem start?
Does the issue affect only one user or multiple users?
Were there recent changes to the system or configuration?
If only one user is affected, the issue is often related to:
local settings
user permissions
the specific workstation
If multiple users are affected, the cause is often related to the system or an integration.
Check for recent system changes
Many issues occur after changes to the system.
Please check whether:
a configuration change was made in PTV Route Optimiser
a system update was installed
an interface or integration was modified
If changes were made, note:
what was changed
when the change was implemented
which components or systems were affected
This information can be helpful during further analysis.
Problem: Orders are not imported
New orders do not appear in PTV Route Optimiser.
This may also occur if:
no orders are visible in the system
new orders are not displayed
the order import appears to stop working
Please check
Are the import jobs running?
Are new entries created in the import history?
Which import type is configured?
Common import types include:
DSC
SAP
TransferDB (TDB)
WebAPI
Excel Import
Possible cause
If no new entries appear in the import history, the upstream system may not be sending order data.
Problem: Tours cannot be planned
Tour planning in PTV Route Optimiser starts but no tours are created.
the planning process finishes without results
vehicles are not assigned to tours
the planning run produces no output
Please check
What message appears under “Info last planning”?
Are the vehicles marked as available?
If vehicles are not available or planning parameters are incorrect, tour planning cannot be completed.
Problem: Tours are not exported
Planned tours from PTV Route Optimiser are not transferred to downstream systems.
tours do not appear in the target system
tour data is not transferred
the export process appears to fail
Please check
Have the tours been released?
Which export type is configured?
If TransferDB (TDB) is used:
Verify that a database connection to the configured TransferDB is available.
Problem: Telematics is not working
Tours from PTV Route Optimiser are not transmitted to driver devices or telematics systems.
tours do not appear on the driver device
tour data is not transferred to the telematics system
vehicles do not receive tour information
Please check
Which telematics provider is used?
Is WebFleet being used?
Is the background service for the telematics integration running?
If the background service is not running, tours cannot be transmitted.
Problem: Reporting is not working
Reports from PTV Route Optimiser cannot be opened or displayed.
reports do not load
reporting results are empty
an error occurs when opening reports
Please check
Is the SQL Server Reporting Server reachable?
Is the connection configured correctly in the PTV Route Optimiser options?
Check import and export history
The import/export history in PTV Route Optimiser can provide useful information when troubleshooting.
Please check:
Are error messages displayed?
Are new entries still being created?
If no new entries appear:
Check whether the background service is running
Restart the background service
If no entries appear afterwards, the upstream system is likely not sending new orders.
Verify the source of the error message
Please verify whether the error message actually originates from PTV Route Optimiser.
If the message comes from another system, the issue should first be investigated with the internal IT team or the responsible system owner.
Check relevant services
Verify that all required services are running.
Typical services include:
telematics services
notification services
xServer services
background services for import and export
If possible, also check the log files of these services.
Check the application log
If the issue persists, review the PTV Route Optimiser application log for:
error messages
warnings
unusual system messages
These logs can help identify the root cause.
Contact support
If the problem persists, please contact support and provide the following information:
description of the issue
when the problem started
which troubleshooting steps have already been performed
relevant error messages
log files
screenshots
Providing this information helps support analyze the issue more quickly.
Comments
0 comments
