Applies to: PTV Navigator G2 administrators — devices running a 32-bit Android system.
The current release of PTV Navigator G2 supports 64-bit devices only: version 1.7.x and higher requires a 64-bit device. For devices that run a 32-bit system, a separate 32-bit version is available.
Android has supported 64-bit since version 5.0 (Lollipop). The Android version alone doesn't tell you whether a device is 64-bit, though — that also depends on the device's processor and system build.
Comments
0 comments
