Answer
Using the latest GCD data with older map versions is not recommended as it may cause unexpected side effects due to geocoding locations that might not be available in old map versions. The best practice is to use the latest GCD data with the latest map data.
Additional hints
Make sure that the latest GCD data is located in the /gcd folder of the installed and configured map data.
Comments
0 comments
