Symptom
A customer compares:
- the real mileage recorded by a GPS tracking system,
- and the distance returned by PTV xRoute for the same trip.
Example:
- GPS/tracking system distance: ~138 km
- xRoute calculated distance: ~218 km
The route is calculated using:
- xRoute
- more than 100 waypoints extracted from GPS positions
- toll calculation use cases
Despite the high number of waypoints, the reconstructed route differs significantly from the actual driven path.
The issue is typically observed when trying to:
- estimate toll kilometers,
- replay historical trips,
- reconstruct real vehicle trajectories from GPS traces.
Cause
This behavior is expected and is related to the fundamental difference between:
- route calculation (xRoute)
- and map matching (xMatch).
xRoute behavior
xRoute does not reproduce the exact driven trajectory.
Instead, it:
- calculates a legally routable path,
- optimizes according to routing rules,
- and may choose roads different from the ones actually driven.
Even with many waypoints:
- xRoute is not designed to strictly follow raw GPS traces,
- intermediate GPS points are treated as routing waypoints, not as a continuous trajectory.
This can lead to:
- route deviations,
- longer distances,
- different toll sections,
- and inconsistencies compared to telematics systems.
Why the difference can become large
Several factors can increase the gap between GPS mileage and reconstructed routing distance:
- sparse GPS sampling,
- inaccurate GPS positions,
- missing intermediate points,
- off-road snapping behavior,
- routing optimization decisions,
- toll-preferred or legally valid alternative roads.
Important distinction
| Use case | Recommended service |
| Calculate an optimal route | xRoute |
| Reconstruct a real driven path from GPS traces | xMatch (Map Matching) |
Resolution
For toll analysis and reconstruction of real vehicle trajectories, use xMatch instead of xRoute.
Recommended approach
Step 1 — Use xMatch (Map Matching)
xMatch is specifically designed to:
- match GPS traces to the road network,
- reconstruct the actual driven path,
- improve toll distance estimation.
Unlike xRoute, xMatch does not recalculate an optimal route.
Step 2 — Ensure sufficient GPS density
Map matching quality strongly depends on GPS trace quality.
Recommendations:
- provide dense GPS traces,
- reduce the distance between recorded positions,
- reduce the recording time interval,
- avoid large gaps between points.
Sparse GPS data may cause:
- matching gaps,
- incorrect path reconstruction,
- incomplete toll calculations.
Step 3 — Handle possible gaps
If GPS points are too far apart:
- xMatch may not reconstruct a continuous path,
- additional routing between matched segments may be required.
This gap-filling step is not automatically handled by the standard xMatch workflow.
Comments
0 comments
